Multiple copies of widget in builder
6368
15
01-13-2016 01:35 PM
RichardMacNeill1
I am making a start on widget development, and have developed and deployed a widget after several false starts. After a false start attempting to deploy a faulty widget, I removed the widget folder from the widgets parent folder, corrected the problem, and then replaced it. I now have four copies of this widget in the builder. Two have an icon (one is a copy) and the other two do not respond and have no icon.
How do I clean this up by removing unnecessary or duplicate widgets?
Tags (1)
RobertScheitlin__GISP
Richard,
   Go into the [install dir]\server\db folder and delete the repoitems file. The file will be automatically re-created and the errant widgets should not appear any more.
Richard,
RichardMacNeill1
Thanks Robert.
I've found the file alongside a newly created apps file. At what point does is the file recreated? Do I need to restart anything?
Richard,
   It will be re-created once you restart WAB (meaning close out the cmd window and re-launch the bat file).
RichardMacNeill1
UNCLASSIFIED
Thanks yet again Robert.
The file has reappeared when I redeployed the Widget. However, I am not seeing this deployed widget among the available widgets in my app.
Richard MacNeill | SENIOR GEOSPATIAL SPECIALIST
National Native Title Tribunal | Geospatial Services
Level 10, Commonwealth Law Courts Building, 305 William Street, Melbourne, Victoria 3000
Telephone (03) 9920 3001 | Facsimile (03) 9606 0680 | Email [email protected]<mailto:[email protected]>
Freecall 1800 640 501 | www.nntt.gov.au<http://www.nntt.gov.au/>
Shared country, shared future.
Richard,
   If you are saying that your custom widget is not appearing in the list of available widget once you have deleted the repoitems file then you have an issue in your manifest.json or widget.js that is preventing it from being added. you can check the appbuilder.log in the [install dir]\server\logs folder and see if there is a clue there.
RichardMacNeill1
UNCLASSIFIED
Thanks Robert. I'll persevere.
Richard
Richard,
   If you like I can take a look. All you need to do is zip-up the whole widget folder and attach to a thread using the advanced editor and attach link.
RichardMacNeill1
UNCLASSIFIED
Thanks Robert
I have taken the liberty of attaching the zipped file folder.
I'm a newby at this (at least the widget side of things), so the attached is the most simple of widgets basically saying hello. It is identical to that which was visible before the file removal (which I have a backup of).
I did see that there is another file is the server/db folder - apps - that seems also to be recreated. Should I delete this also?
Richard
RichardMacNeill1
UNCLASSIFIED
Apologies Robert. All is good and all themes and widgets are visible. The problem was on our side. Your advice has been extremely useful.
Geospatial Services | Melbourne
Telephone: (03) 9920 3001
