Make Popup Moveable
1167
01-04-2019 06:48 AM
RichBell
What changed in WAB 2.9 to make this code not work?
I want to make a popup moveable.
mo.createWebMap = function(portalUrl, itemId, mapDiv, /* optional */ options) {
portalUrl = portalUrlUtils.
getStandardPortalUrl(portalUrl);
var itemUrl = portalUrlUtils.getBaseItemUrl(portalUrl);
arcgisUtils.
arcgisUrl = itemUrl;
var def = arcgisUtils.createMap(itemId, mapDiv, options);
def.then(function (response){
var map = response.map;
var handle = query(".title", map.infoWindow.domNode)[0];
var dnd = new Moveable(map.infoWindow.domNode, {
handle: handle
// when the infoWindow is moved, hide the arrow:
on(dnd, 'FirstMove', function() {
// hide pointer and outerpointer (used depending on where the pointer is shown)
var arrowNode = query(".outerPointer", map.infoWindow.domNode)[0];
domClass.
add(arrowNode, "hidden");
var arrowNode = query(".pointer", map.infoWindow.domNode)[0];
domClass.
bind(this));
return def;
RobertScheitlin__GISP
Rich,
   Is it just the arrow not being hidden or is it nothing is working at all?
Rich,
RichBell
My Bad I forgot to add this
define([
    'dojo/dnd/Moveable',//BELL CHANGE
    'dojo/dom-class',//BELL CHANGE
