Layers visible on portal map
994
02-14-2021 03:05 AM
KafilBaig
Hi ,
I want to control the visibility of the layers in arcgis portal map based on the user privileges.
for example a user has only privilege to see point of interest layer and not street layer.
When the webappbuilder application loads the map I want to control this .
Is this possible to do. Please suggest.
Thanks in advance
DavidPike
MVP Notable Contributor
I think you'd have to have each layer shared to specific access groups, reduced-access users will just see 'x,y,z layer could not be added to the map' on loading.
