Is there any way possible to change the pop-up position of the summary results in WebApp Builder Developer?
1793
08-23-2016 02:00 PM
KestonMoses
Good day,
I have recently started using the WebApp Developer Edition. I am trying to locate the file in the "Summary" widget folder that allows me to edit the way the summary results pop-up. I am attempting to allow the results to pop-up from the side instead of the bottom. Any suggestions available?
RobertScheitlin__GISP
Keston,
   This would be a pretty big re-write of the Widget.html and the style.css. The style.css is where most of the css rules exist to specify that the panel is on the bottom. I don't use the Summary widget and have never had a need to make such a change so I can not provide more.
KestonMoses
Thanks for the info Robert.
I will check the style.css to see which line of code influences the pop-up style.
