Incident Analysis Widget Error
5440
7
01-06-2016 03:59 PM
CharlesGuiam1
Not sure where to post this error with the Incident Analysis Widget's tabs. This is using the embedded WebAppBuilder (not developer's edition).
Here are my settings:
Click a tab to list AGOL hosted features within the selected buffer results in this:
But clicking to another tab results in still showing the same selections from the first tab:
Bug or configuration error?
I replicate this across feature layers served from ArcGIS for Server, as well as hosted in AGOL.
I could use a solution otherwise I will only be using one tab to show features within a user specified buffer.
Also, I could not figure out if this uses credits and why or why not. Clarification much appreciated
CharlesGuiam1
Yay I found a bug. I hope this gets fixed.
Bug detail:
BUG-000093510: Incident analysis widget within WebApp Builder application does not reflect the changes while switching tabs.
Does this widget use service credits?
YES, according to esri support staff. It uses the spatial analysis credit tiers 1 credit per 1000 features.
*Side note for developers:
It would be awesome if the tool could create multiple buffers and see intersecting features where the two buffers overlap. I would appreciate if anyone could share a working widget or similar code for this.
AravindatStoryMaps
Used the incident analysis widget in WAB
Here are my results:
Selection from Tab #1:
Selection from Tab #2:
Are you working with WAB developer or the online version of WAB?
Aravind
CharlesGuiam1
Online Version
AravindatStoryMaps
Another thing that I noticed with the app was that it referenced two different values for the fields that came from the two layers. This makes me wonder if the selection was pointing to the same values for both. Would you mind changing one of the layers to "Closest Feature" instead of "Proximity" on both layers?
Aravind
CharlesGuiam1
Aravind,
Using the two different "Analysis Types" for "Closest Feature" and "Proximity" work the same way as my error.
My error shows regardless of setting layers to proximity. Once an incident is given a buffer, I click on one of the tabs to view results; the buffer list/display works fine. I then click on the second tab to view results; the buffer list/display works fine. THEN I click  back on the first tab results; the buffer list is fine but the display hangs on the last tab I clicked on (aka the numbering for how many of the second layer is within the buffer stays the same). This is the same error I get when using different "Analysis Types."
I added a third "proximity" layer, clicked through the first, second, and third tabs, then back to the second or first tab, the display hangs on the last results tab I clicked on.
This makes me think the incident analysis widget displays the numbering (in the map) based on the last layer results tab that is clicked open.
I have replicated this using the billboard theme and dart theme and using same/different "Analysis Type" for configuration.
JunshanLiu
Charles,
Could you post your console error here to help us find the reason? I can't reproduce your issue.
CharlesGuiam1
Esri Support Esri Case #01727204 is able to reproduce my error. I do not know where to find the "console error."
CharlesGuiam1
Bug detail:
