Identify widget strange behavior
3874
12
09-21-2016 02:00 PM
LeoLadefian5
I'm having an issue with one of my layers depending on if it's toggled on or off in the layer list.
Here is the example, when the below configuration is selected, the identify widget works fine:
When the below configuration is used, the identify widget fails to return any values.
When they are both selected the identify widget works as it should.
rscheitlin
Can anyone replicate this? here is my app:
Planning Viewer
RobertScheitlin__GISP
Leo,
  I have found the issue(s) and will have it fixed in version 2.1.1 of the widget. The widget now Truly respects layer visibility based on scale and layer checked state.
LeoLadefian5
Thank you so much, can I use the new widget in wab 2.0? or do I need to upgrade the app.
You will need to upgrade.
