How to reverse the direction in Near Me Widget?
1200
03-01-2018 06:36 AM
HushamMohamed
Is it possible to reverse the Direction in The Near Me Widget? So the direction should be from the (search layer(s)) to the user Point.
Many Thanks
RobertScheitlin__GISP
Husham,
   It should be as simple as swapping the order that the stops are added to the selectedLocations array in the _routeSelectedLocations function in the items-list.js file in the widget folder.
currently is has this:
selectedLocations.push(this._getPointFromGeometry(this._selectedPoint.geometry));
selectedLocations.push(this._getPointFromGeometry(this._selectedFeature.geometry));‍‍
If you add reverse:
selectedLocations.push(this._getPointFromGeometry(this._selectedFeature.geometry));‍‍‍‍
selectedLocations.reverse();
Then it should get you what you want.
Husham,
If you add reverse:
HushamMohamed
Thank you so much it worked perfectly
