How to Implement Custom tool Validation for Geoprocessing Widget
11358
14
09-16-2015 10:11 AM
AlexisGreen
I've added a geoprocessing service to the Geoprocessing widget in Web AppBuilder.  Within the GP tool that was authored in ArcGIS Desktop, I have some custom validation logic written using Python, which works fine when running the GP tool in ArcGIS Desktop, but which is ignored when publishing the tool as a GP service and running it via Web AppBuilder's Geoprocessing widget.  The UI for my tool consists of 2 drop-down menus to collect the 2 input parameters from the user.  The parameter validation needs to happen before tool execution, and I need the validation logic to update the values in the 2nd drop-down menu based on the value that the user chooses in the 1st drop-down menu.
It seems that a possible approach to implementing this type of special validation code would entail using the Developer Edition of Web AppBuilder to customize the "Settings UI".  Anyone have experience with this type of client-side parameter validation in Web AppBuilder who would be willing to share some tips with me?  Is this something that would be relatively easy to do, or does it require advanced JavaScript development or experience with the API?  Thanks for any feedback.
LanceKirby2
Any update on this? I am trying to publish a gp service to be used in WAB that allows the user to select any layer within the first parameter and have a dropdown in the second parameter of fields associated with that layer.
JyotiRohodia
Hi Lance,
I think you can achieve this workflow using a script tool in ArcGIS Pro. Configure Field type parameter and set "Dependency" on the input layer.- inside script tool properties.
Hope this helps.
LanceKirby2
Thanks Jyoti. I've tried to get that to work several times. I was hoping someone could confirm that they have actually implemented it!
tigerwoulds
I'm hitting the same wall with a very similar issue. Unfortuatenly I think validation code from a working Python toolbox does not carry over to the GP Widget in WAB. This guy had this same problem and 2016 and suggests building the functionality in JS rather than python. Ugh...
3 Lessons I Learned from Publishing Geoprocessing Services in ArcMap (ifeomacollins.com)
SerjStol
I ran into this issue now on ArcGIS Enterprise 11.3, validation of the parameters does not work when you publish a Web Tool from ArcGIS Pro, while it works in Pro. I have made a tool using Python Toolbox and require dropdown to be populated based on the layer chosen in the first parameter.
I embeded the custom GP Tool in the Experience Builder Analysis Widget and it still seems that its not possible, the parameters remain static with the values you used when you run the tool in Pro.
