How to create an attachment with the current map screenshot ?
2434
06-05-2017 05:39 AM
esriuser2
I am adding a custom widget to send an email with some description and map screenshot.Is there a way that I can create an attachment with the current map screen shot and is there any geoprocessing service to send an email ?
Thank you!
RobertScheitlin__GISP
esri user,
   I use the Print service for this with the map only template chosen.
    'esri/tasks/PrintTemplate',
    'esri/tasks/PrintParameters',
    'esri/tasks/PrintTask',
  function(
    PrintTemplate, PrintParameters, PrintTask,
        map.infoWindow.hide();
        var oWid = map.width;
        var oHgt = map.height;
        var printTask = new PrintTask('.../rest/services/ExportWebMap/GPServer/Export_Web_Map');
        var template = new PrintTemplate();
//calc for maintaining the maps aspect ratio
        template.exportOptions = {
          width: 1542,
          height: (1542 / oWid) * oHgt,
          dpi: 200
        this.imgHeight = (1542 / oWid) * oHgt;
        template.format = 'jpg';
        template.layout = 'MAP_ONLY';
        template.preserveScale = false;
        template.showAttribution = false;
        template.outScale = map.getScale();
        var params = new PrintParameters();
        params.map = map;
        params.template = template;
        printTask.execute(params, printResult);
      function printResult(rsltURL) {
        var mapImg = domConstruct.toDom('<img src="' + rsltURL.url + '" border="0" style="width:740px;height:"' + this.imgHeight + ';"/>');
        domConstruct.place(mapImg, mapImgDiv, 'replace');
ThomasSolow
ArcGIS Server/Portal does not come with an email server.  If you have access to an email server then I imagine you could set this up.
esriuser2
Is there a custom code or widget that take a screen shot of the webapp window and give the option to save the image file ?
Thank you!
ThomasSolow
There are two ways to do this that I know of.  If it's a 3D sceneview in the 4.X API you can use scene.takeScreenshot.  If you're using 3D I can give you an example.
If you're not, I recommend using this third party open source library: GitHub - tsayen/dom-to-image: Generates an image from a DOM node using HTML5 canvas
I know a few people who have successfully extracted a jpg from a 2D map using that.
esriuser2
Thank you Thomas! I am using 2D map, and above one seems not supported in all browsers
esri user,
  function(
          width: 1542,
          dpi: 200
        params.map = map;
