How do I add bookmarks via code to bookmark widget in web app builder application?
8801
10
02-26-2015 10:36 AM
BrandonKeinath1
I’m trying to add a number of new bookmarks into an existing web app builder application we have on our arcgis server.  I believe that I’ve followed the correct syntax but the main issue is that I’m not seeing any changes when I edit the config.json file in the bookmark widget folder.  I’ve tried clearing my cache, creating a new application with the new file, yelling, etc.
Can someone help me with the correct workflow or with tricks for adding new bookmarks to an existing web app builder application bookmark
config.json?
Brandon
BrandonKeinath1
Ok, well that does make sense.  Unfortunately nothing is different following the command and resulting "undefined".  I'll report back on the eventual solution.
Brandon
