Hiding labels in extent
1436
01-27-2021 02:48 AM
by Anonymous User
Not applicable
I am trying to hide or disable the distance labels in the drawn extent
The client doesn't need the distance tool in the Draw widget, so I am hiding the entire distance div. The thing is, since it's still active /ON, it shows the distance in the drawn extent on the map. Any advice on how to proceed to disable it /turn it off from the map?
Tags (3)
RobertScheitlin__GISP
Justin,
  If you are talking about the OTB Draw widget there is a configuration for showing the Perimeter measurement label.
https://developers.arcgis.com/web-appbuilder/guide/widget-draw.htm#ESRI_STEP_FDBDCF97C9534A23A0F2973...
