Hi All, Is it possible to change the map extent when loading the application?
1281
02-02-2017 09:13 PM
Raghunatha_ReddySura
Hi All, Is it possible to change the map extent when loading the application? I tried to change the extent in MapManager.js Show2dWebmap method, but noluck...
RobertScheitlin__GISP
Sure, have you seen that you can do this using a url parameter?
Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
