help with eSearch Widget
834
06-13-2022 01:32 AM
Labels (2)
GuyShaharabani
I need to find features from one layer(between selected dates), that don't contain features from another layer within a radius of 150 meters from them.
I know I can do it with the eSearch widget but I'm still struggling to do so.
RobertScheitlin__GISP
@GuyShaharabani  so if I understand the desired results then the workflow would be:
  1. Select the desired features from the other layer using the by value tab
  2. switch to the spatial tab and set the buffer to 500 meters and then click the buffer button
  3. change the "search features from" to your desired layer and select the "intersected by" button
  4. Now switch back to by value tab and and be sure the search layer drop down is set to your desired layer, then click the drop down just to the right of the search layer dropdown and choose "remove from current results" and then set the date range that you do not want to appear in the results.
