Filter widget not respecting field alias
1356
05-20-2019 11:15 AM
ZorbaConlen1
Hi. I'm noticing a small bug (I think) with the WAB filter widget. I have the widget set up with a couple filters and it works fine, but references to fields are using the field name rather than the field alias. See below. I believe that if features in a map service have fields with aliases setup, those should be respected in WAB widgets.
I also tried configuring an alias in the popup "configure attributes" settings of the web map. No luck.
Anyone else seeing this?
filter interface
service rest website
Tags (3)
RobertScheitlin__GISP
Zorba,
   I am afraid that the widget is working as designed. You will have to submit an enhancement request.
Zorba,
ZorbaConlen1
Ok, that's what I figured. Weird though. I assume esri would understand that database field names are not meant to be presented in the UI.
