Filter Widget in Web AppBuilder can't filter twice on same layer, help.
913
03-13-2023 09:19 AM
JonJones1
Hello all,
I have two separate filters built for the same layer within the filter widget of the Web Appbuilder. However, I don't get the results as expected. If I enable filter one alone 10 objects should turn off, if I enable filter two alone 1 object should turn off. However, if I enable filter 1 and filter 2 simultaneously, nothing turns off at all, and all 11 objects are present.
I could explain it all more thoroughly with an example but before I go into that detail, I just wanted to ask the quick question, is it possible to have more than one filter enabled at a time on the same layer with just the “Filter” widget? Or should I be using the “Group Filter” widget?
JonJones1
Just wanted to toss this out there in case somebody reads my post and wants to know the answer.  The answer is to change this option to "Display features that match ALL the filters"   the default is "display features that match ANY of the filters".    See attachment for what I mean.
