Extend Enhanced Search Widget
7854
20
04-13-2016 03:13 PM
soniamonga
Robert,  I have task where I need to select a predefined value from a drop down, and based on that value it queries the underlying layers. Your widget works great if I have to query a single layer. Can anyone of you suggest a sample or a widget that I could use?
Sonia
Tags (1)
RobertScheitlin__GISP
Sonia,
Can I see your current code where you define the feature layer and its out fields?
soniamonga
Robert, I have attached the code for your reference. Thanks again for all your help!!
Sonia,
  You have to use the proper case for your field names JS is a case sensitive language.
query.outFields = ["SORT_TEXT","CITY", "COUNTY"];
soniamonga
Ok. let me try that. Any idea on the refresh part? When I select a new county from the drop down it doesn’t remove/refresh the previous selection. I might have removed the reset function from the code.
Sonia,
Are you using FeatureLayer.clearSelection()?
soniamonga
Yes. I have tried that.
Sonia,
  Not sure what to tell you then as
featureLayer1.clearSelection(); should work.
soniamonga
Robert, I have struggled over the weekend on this.. The featureLayer1.clearSelection() does work but looks like I am not passing it at the correct location. Would you please take a stab at the code and see which function and how I should be using it?
Thanks so much…..
Sonia,
When you want a var available in any function in the widget you define it this way:
return declare([BaseWidget, _WidgetsInTemplateMixin], {
    // DemoWidget code goes here
    baseClass: 'jimu-widget-demo',
    zipcodes1: null,
    startup: function() {
        this.inherited(arguments);
        console.log('startup');
        //var zipcodes1;
    _onchgclearfeatures: function() {
        alert("clear");
        this.zipcodes1.clearSelection();
soniamonga
Thanks so much Robert for all your help so far!
