Is there a widget that allow me to download a layer from an app on webappbuilder?
Carlos,
There is the Extract Data tool in the Analysis widget.
Analysis widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Carlos,
Don't forget to mark this question as answered.
Hello Robert. Can we use this tool without arcgis online? I imported a feature service from our arcgis server that it was published with the extract task enabled. Then, I open this tool and the imported layer was listed in the "Layers to extract". I defined an area for extraction to a shapefile. It failed. Do we need to need hosted layers only in arcgis online? This tool works only with credit$? Thank you.
