District lookup issue
746
06-03-2019 11:07 AM
ColumbusHawks
     Not sure what changed  but seems like since the last AGOL update the District lookup Widget is working correctly.
If you use "1"  Source for addresses it appears to work OK . However ,  I am using 4 Sources for searching,  Prior to the update you could type in the whole address and it would give you the "list" of all the searches that matched. Now if you type in the "#" then you have to click back in the search box to continue typing.Sounds like not a HUGE deal but, if it worked correctly before.... What changed ?
Anyone else seen this issue ? district lookup #agol #
