Dashboard Theme Webapp Builder - Tile size
2606
04-07-2020 05:15 AM
PamelaLocke1
Is there a way to resize the tiles and have them show that way by default when using the dashboard theme in Webapp Builder?  I am using the dashboard theme with the 9 tiles.  I would like to make the map tile bigger by default when you first open the app.
Thanks!
Pamela
BenTurrell
Hey Pamela Locke‌,
When you are configuring your dashboard you can click Modify Layout to add more dashboard panels/widgets but you can also resize the dashboard tiles in here.
I've added a short video as it was a bit hard to put into words.
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
PamelaLocke1
Hi Ben,
Thanks for the Reply!  Where do I find the "Modify Layout"  button?  I don't seem to see it on my screen....
Pamela
BenTurrell
Hey Pamela Locke‌,
You can use either of these two buttons:
Ben
PamelaLocke1
hmmm, i don't seem to have those buttons!
