custom widget for ArcGIS Online Development Related question
2966
5
12-22-2016 03:42 AM
Awet_Tekle
Hello all,let me post my partial code in which I have difficulty to figure out its solution: I have a button with "FadeIn" id and I want to call the FadeInPrimaryOpacity(op) function for each value of i repeatedly till the limit value of i is reached after the FadeIn button is pressed.so,is there any wrong with my code
postCreate: function() {
registry.byId("FadeIn").on("click", lang.hitch(this, this.PrimaryLayer_Visibility));
PrimaryLayer_Visibility:function () {
// don't worry about "this.primaryLayer" since this is partial code of the whole code
if (this.primaryLayer.visible) {
for(var i=0;i<=10;i++)
setTimeout(function(){
FadeInPrimaryOpacity(i/10.0);
},2000);
} else {
for(var i=10;i>=0;i--){
},2000);
FadeInPrimaryOpacity:function(op) {
this.primaryLayer.setOpacity(op);
RobertScheitlin__GISP
Awet,
   OK your logic was incorrect.
            PrimaryLayer_Visibility: function() {
                if (this.primaryLayer.opacity > 0.9999999999999999) {
                    this.FadeInPrimaryOpacity('out');
                } else {
                    this.FadeInPrimaryOpacity('in');
            FadeInPrimaryOpacity: function(dir) {
                if (dir === 'out') {
                    if (this.primaryLayer.opacity > 0) {
                        this.primaryLayer.setOpacity(this.primaryLayer.opacity - 0.1);
                        setTimeout(lang.hitch(this, function() {
                        }), 1000);
                } else {
                    if (this.primaryLayer.opacity <= 1) {
                        this.primaryLayer.setOpacity(this.primaryLayer.opacity + 0.1);
                        }), 1000);
Awet,
  Here is what I saw wrong corrected:
    for(var i=0;i<=10;i++) {
      setTimeout(lang.hitch(this, function(){
        this.FadeInPrimaryOpacity(i/10.0);
      }),2000);
  } else {
      }),2000);
Also in templated widget development you normally do not use
you would normally use:
this.FadeIn.on("click", lang.hitch(this, this.PrimaryLayer_Visibility));
Because in the html template you would have:
<button data-dojo-type="dijit/form/Button" data-dojo-attach-point="FadeIn" type="button">Fade In</button>
Notice the use of data-dojo-attach-point instead of id attribute.
Awet_Tekle
Robert,
Thank you very much for your continuous help, but still notworking,I don't know why it is.
Awet,
                } else {
                        }), 1000);
                } else {
                        }), 1000);
Awet_Tekle
Robert,
Thank you very much,problem solved.
Awet,
   You should mark the reply that answered your question as the "Correct Answer" to allow others to easily find the correct answer. You had marked your own reply as the correct answer by mistake so I unmarked it.
