Custom WAB Template : Feature creation is disabled for all layers.
8183
8
05-20-2015 09:06 AM
AndyAston
I’m stumped...I setup a custom WAB app (Dev Edition), including the out of the box Edit widget and a custom widget.  My Feature Layer has editing enabled and it's functional in the Web Map.  When I share it to my custom WAB template and click on the Edit widget I get this message: Feature creation is disabled for all layers.  No issues with a standard WAB template.  Ideas?
AndyAston
Update: This has been isolated to an issue with the WAB Export As Template and the Edit widget.  It's identified as a bug with Esri now.  The short-term solution is to build the app with a defined web map.  More to come on a long-term resolution with a template-based workflow.
StanMcShinsky
Andy,
Glad you are figuring it out. It sounds tricky.
-Stan
JoaoManuel
Hello.
Im having the same problem. Has this bug been fixed?
It seems this is the only thread with this issue reported. Can someone enlight me, please?
Cheers.
AndyAston
This is a reported bug (BUG-000087970).  It's been "in process" for a year now, but the status shows as "In Product Plan" and it's now ranked as a "High" priority.  Hopefully that's in line with your timeframe.
JoaoManuel
Its not in line of my timeframe, but thanks for the answer.
KatieSteele
Andy Aston,
Did this bug ever get fixed? I have the same problem, too.
MegHoole
If you get the error in the web map too, it may be related to z-aware layer published from ArcMap:
How To: Edit a z-aware hosted feature layer in ArcGIS Online
JonathanPollack
This still appears to be an issue (at least in Enterprise 8.1).  I had to disable z-values in my data and re-publish to allow editing.
