Custom Cache Scales on Web Map Applications
943
08-23-2017 07:16 AM
StevenFernandez
Hello,
I created custom scales in my Tile scheme of a drone orthophoto.  Uploaded to AGOL as a hosted Tile Layer.  Now the image is only showing at one of the scales, even though 4 of them match (564, 282, 141 & 70).  Not exactly sure which one.  I set my web map to have the same custom scales.  Any info on what's going on.
RobertScheitlin__GISP
Steve,
   If you are using standard esri basemaps then your basemap needs to match their scale reduction.
For example you take the lowest scale and divide by 2:
These should be your scales:
564.248588
282.124294
141.062147
70.5310735
35.26553675
17.632768375
