Change WAB language
1667
06-06-2019 05:28 AM
AntonioFraga
Hi!
I wish to know if it would be possible to change the WAB language  on the fly once the app is loaded via programming a specific widget. The goal is change it dinamically using a selector.
All suggestions are welcome.
Thank you!
Antonio
Tags (1)
KoenDemonie
By default, WAB takes the language setup in on your portal-account profile.
Nonetheless you can change it at runtime by adding : " locale=<lang>" url param.
the <lang> should be of format ISO 639-1.
ex.
https://<WAB-URL>?id=2&locale=fr
José_LuisCc
Good but.... and the customized ?
