Cant fire up or deploy WAB application
1179
07-18-2018 12:54 PM
joerodmey
Trying to deploy my web app from WAB to my own web server but app hangs on the loading screen (screenshot attached). This is also the case when I try running the app locally when I fire up the the index.html. Thinking it was some custom code in the app, but i tried "dummy" plain apps and still the same result.
What may be causing this issue?
Thanks
RobertScheitlin__GISP
Joe,
   You can not run the app from the file system like you are attempting to do (notice the file:// in the url) you need to use your machine name or at least localhost.
joerodmey
Screenshot attached
Joe,
