Cannot use "blank" selection in Filter Multi-Select Widget
1285
07-11-2022 08:02 AM
JessicaLott_Dymaptic
I am trying to allow users to be able to use multi-select in the filtering widget. The issue is that if they select the "blank" option, it does not filter out the ones with no value and it acts like nothing is selected. This seems to be a bug with the widget itself. Has anyone else noticed this same behavior? Were you able to find a work around without adding a ton of "Is Blank" filter expressions?
