Cannot add a custom basemap to the Basemap Gallery
8704
12
03-28-2017 02:14 PM
KenBuja
MVP Esteemed Contributor
I am getting the error "The basemap you are adding has a different spatial reference from the current map." when trying to add a custom basemap (NOAA Nautical Charts) to the Basemap Gallery widget. I was able to add this basemap to an app in a previous version of the WAB and the basemap does still work. But when I edit that existing app, I get that same error.
Was there a bug introduced in the March update?
Tags (1)
by Anonymous User
Not applicable
Caroline, I will plan to do that thanks.
AndrewHayden1
I'm running it to this issue in WAB 2.9.  Could anyone confirm if this issue persists?
CarolineGarris
Hi Andrew,
I'm not seeing any new defects for this. Defect BUG-000104277 has been marked as resolved. I would recommend creating an Esri Support case in regards to the issue.
Best,
Caroline
