Can I display current scale in web app builder application?
27034
36
02-20-2015 05:07 AM
BrandonKeinath1
I would like to display the current map scale to the user in a web app builder application.  Is this possible using a widget or does it require additional code?
If it requires additional code has anyone done this successfully and could share some resources/hints?
Update:
I should have been more specific in my question.  I'm interested in knowing if the user is at 12,345 or 1,128 rather than giving them the ability to measure using a scalebar.  My goal is to have some way to know when a user is asking why they can't see a layer to be able to tell them how far to go in.  Or if they say that it needs to be visible at a certain scale I can quickly make the change rather than educated guessing.  Is there another way to accomplish this goal?
Message was edited by: Brandon Keinath
WilliamMiller4
Hi Tim,
I have the scale in the header-controller widget, but it does not change with the map. It gets the initial scale of 1:180,000, but is static after startup. Below is what the postCreate and startup functions look like:
      postCreate: function() {
        this.inherited(arguments);
        this._processGroupSetting();
        this.switchableElements.title = this.titleNode;
        this.switchableElements.links = this.linksNode;
        this.switchableElements.subtitle = this.subtitleNode;
        domClass.add(this.scaleInfo, "coordinate-background"); //I'm not sure what to reference here
        this.own(on(this.map, "extent-change", lang.hitch(this, this.onExtentChange)));//added for scale
        if (this.position && this.position.height) {
          this.height = this.position.height;
        // if (!this.appConfig.portalUrl) {
        html.setStyle(this.signInSectionNode, 'display', 'none');
        // } else {
        //   html.setStyle(this.signInSectionNode, 'display', '');
        if (this.appConfig && this.appConfig.logo) {
          this.logoNode.src = this.appConfig.logo;
          html.removeClass(this.logoNode, 'hide-logo');
        } else {
          this.logoNode.src = "";
          html.addClass(this.logoNode, 'hide-logo');
        this.switchableElements.title.innerHTML =
          utils.sanitizeHTML(this.appConfig.title ? this.appConfig.title : '');
        this.switchableElements.subtitle.innerHTML =
          utils.sanitizeHTML(this.appConfig.subtitle ? this.appConfig.subtitle : '');
        this._createDynamicLinks(this.appConfig.links);
        this._setElementsSize();
        this.own(on(this.domNode, mouse.enter, lang.hitch(this, function() {
          var title = '';
          var portalUrl = this.appConfig && this.appConfig.portalUrl || '';
          var server = portalUrlUtils.getServerByUrl(portalUrl);
          if (portalUrlUtils.isArcGIScom(server)) {
            server = 'ArcGIS.com';
          if (server) {
            title = this.nls.signInTo + ' ' + server;
          this.signinLinkNode.title = title;
      startup: function() {
          var MyMap = this.map; //start of addition for scale
          var MyScaleWindow = this.scaleInfo.innerHTML;
          var MyScaleTest = this.scaleInfo;
          var scale = esri.geometry.getScale(MyMap);
          var myNumber = dojoNumber.format(scale, {
              places: 0
          htmlSet.set(MyScaleTest, "Scale: 1 : " + myNumber);
          this.map.on("extent-change", getmyscale);
          function getmyscale() {
                  places: 0
              htmlSet.set(MyScaleTest, ", Scale: 1 : " + myNumber);
              console.log("Got it");
          }; //end of addition for scale
        this.resize();
        // this.timeoutHandle = setTimeout(lang.hitch(this, this.resize), 100);
Any help would be appreciated, even if it's to tell me the scale cannot go in the header-controller widget. Thanks.
William
TimWitt2
Hey William,
It seems like your "extent-change" event isn't called. Do you get any error messages?
Tim
WilliamMiller4
Hi Tim,
I don't get any error messages. How and where would I call the extent-change? Would I use something like this
this.onExtentChange.startup();
in postCreate or startup?
William
TimWitt2
Line 53  will call your getmyscale function. Can you open the developer console and put a breakpoint at line 55 and see if it runs when you change your scale?
WilliamMiller4
Hi Tim,
I'm using Microsoft Visual Studio 2010 as my main text editor. When I add a breakpoint and debug, I get a directory list for the project. I know Visual Studio isn't ideal for javascript, but that's what I have right now. Are there any free applications you recommend for working with Web AppBuilder? I'm also trying to debug in different browsers (IE, Firefox & Chrome). Right now I'm getting a few errors, but none of them seem related to the HeaderController Widget.js.
William
TimWitt2
I like to use chrome to debug. Just open the developer tools and navigate to the code that you changed and add a break point. Now if you zoom in and out it should pause your code.
TimWitt2
William,
this works for me (code wise). You will still need to style it to fit your needs.
Tim
WilliamMiller4
Tim,
I guess I didn't need to add the following to postCreate.
What CSS class do I reference for styling? Before I had used ".jimu-widget-header-controller .coordinate-scale jimu-float-leading".
Thanks for your help.
William
TimWitt2
You could give it an id and style it like that.
WilliamMiller4
That works. Thanks again for your help Tim!
