Bookmark widget in Web app builder problem
2267
03-03-2017 01:06 AM
deborahrhodes
I created a web app using the web app builder and have several icons for bookmarks which users can click on and zoom to an area. Underneath the icons are the names of the areas which sometimes go onto 2 lines. Prior to the updates, both lines showed but since the updates the second line of the text under the icons is missing. If I go in to edit the bookmarks I can see both lines. Could you tell me if there is anything I can do about this, there is no option to make the text smaller. I have attached an image of the bookmarks, so for instance Greater - should be Greater Manchester or Greater Lincolnshire, Peterborough should be Peterborough and Cambridgeshire.
by Anonymous User
Not applicable
I would like to get a support case created to look into this. I will send you a direct message.
Jianxia
This is a regression introduced in AGOL 5.1 update. We will fix it in the patch tomorrow night. Sorry for any inconvenience.
deborahrhodes
All sorted now, thank you
