Append Geoprocessing Service
1352
02-07-2019 06:54 AM
AndrewMilanes
I would like to perform a very simple geoprocessing task in WAB:
  1. User uploads a CSV file ( 3 text columns and schema matches table in SQL)
  2. Records from CSV are appended to existing table in SQL
So far I have been unable to get this to work.  Steps I've taken:
  1. From Pro 2.3.0, use the append geoprocessing tool to perform the task
  2. Share the result as a Web Tool in Portal 10.6 (upload and asynchronous selected)
  3. Add the GP service in WAB widget
No matter what parameter options I choose, this is the error I receive:
ERROR 000820: The parameters need repair. ERROR 000800: The value is not a member of Input schema must match target schema | Use the Field Map to reconcile schema differences. ERROR 000820: The parameters need repair.
So I tried from ArcCatalog 10.6.1:
  1. Use the append geoprocessing tool
  2. Share the results as a geoprocessing service to Server 10.6 (upload and asynchronous selected)
  3. Add server to GP widget in WAB
Different error with this service:
ERROR 000840: The value is not a File.
The output table is registered with the geodatabase and the SQL connection is registered in Server.
What am i missing?
Thanks
SimonSuo1
File upload is not supported yet in the WAB, and it is currently under discussion to add support for it for the next release. Meanwhile, file upload UI is available in the map viewer of portal.
