Analysis widget change default unit for summarize nearby
2356
05-16-2021 05:21 AM
VictorTey
Hi, I am trying to change the default unit for
They are currently set to Miles and I want to change it to KM.
My organization is set to Metric
In Widget.js -> _switchToAnalysisTool, I also tried to set the unit via the arg which works for create buffer.
Any suggestions?
@RobertScheitlin__GISP  (Any advise from you is much appreciated 🙂 )
@VictorTey,
I have not tested this but it should be as simple as adding these lines to the same function:
        if(this.currentToolSetting.title === 'summarizeNearby'){
          args.units = "Kilometers";
@VictorTey,
VictorTey
Hi @RobertScheitlin__GISP  I have not idea how you know that but it works. I had a break point on the submit hoping to see it in the argument but I don't see units there.  Did you know to use units from the rest endpoint ? Again thank you so much 🙂
https://developers.arcgis.com/rest/analysis/api-reference/summarize-nearby.htm
@VictorTey
I just looked at the available properties for the tool in the documentation.
https://developers.arcgis.com/javascript/3/jsapi/summarizenearby-amd.html#properties
