Add multiple Scale Bar widget styles
1320
10-07-2021 11:54 AM
JacobAalfs
Is it possible to have two scale bar widget styles displayed? I want both ruler and number.
jcarlson
You should be able to add multiple scale bars, but not without getting into some custom JS coding.
- Josh Carlson
Kendall County GIS
GuillaumeArnaud
I think you can modify themes that you use (themes folder) or config.json on root folder if your app is already create. Try to duplicate the part of scalebar widget and modify the position.
