Add Data Widget - CSV file error
3951
10-05-2018 03:30 AM
Sai_Krishna_ChaitanyaSathavall
Hello,
I am trying to upload a csv file to 'Add Data' widget and receive the "Analyze exception null" error. I am using Web AppBuilder Developer Edition 2.9 and Portal for ArcGIS 5.1. However if i try to add the layer in ArcGIS Online with the same CSV file it works fine.
Attached here with the CSV file and error snippet.
RobertScheitlin__GISP
Chaitanya,
   The AGOL WAB version is 2.10 and it must be that they have fixed some issue that you are having with the CSV file. Portal 10.6.1 uses WAB version 2.8. If you wait for Portal 10.6.2 then it will have WAB 2.10.
About release versions—Portal for ArcGIS | ArcGIS Enterprise
Chaitanya,
Robert, Thanks for the information.
Robert,
I was able to add the attached csv file in one of your preview applications
https://gis.calhouncounty.org/WAB/V2.9/widgets/PopupPanel/index.html
The below request is sent after we upload the csv file. In your application the request executes successfully. But the same request to our portal fails.
https://xxxxxxxx.maps.arcgis.com/sharing/rest/content/features/analyze
Please let me know if i am missing anything. Also can we enhance the functionality to upload xls insted of csv?
Thanks
Most of my preview sites are 2.9 so your issue is still that your Portal is using 2.8 and you will have to wait for Portal 10.6.2.
No you can not use xls files.
