Accessing http URL from the application
4802
16
02-21-2018 10:31 AM
VenkataSrikanthDasari
Hi
I am accessing the REST service using esriRequest which is http URL from the portal linked web application.
however the application is accessing using https and response giving unable to load the url status 0.
Please give me solution for this.
Cheers,
Srikanth Dasari
RobertScheitlin__GISP
So when manually add the url to your web browsers address bar does your url work?
Yes
On Wed, 21 Feb 2018 at 2:32 pm, Robert Scheitlin, GISP <[email protected]>
Can you show me the exact url that works and what the return looks like?
Issue got resolved. Actually, I am using esriRequest for a non-esri "SharePoint" service and I have used dojo/request/xhr to resolve issue. Now, I am facing issue with the mixed content "Mixed Content: The page at 'https://localhost:44397/' was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint 'URL'. This request has been blocked; the content must be served over HTTPS"
Please give me some resolution.
Cheers,
Srikanth Dasari
Your only solution is to not mix content. Either use http or https.
SharePoint is only for internal purpose so they are using with http..
On Thu, 22 Feb 2018 at 5:17 pm, Robert Scheitlin, GISP <[email protected]>
But that does not help your mixed content issue.
