Web AppBuilder Edit in Attribute Table
30058
43
05-18-2016 01:28 PM
Status: Open
ChristopherSchreiber
The Esri JavaScript API 3.16 had added editing functionality to the Attribute Table widget. Can this functionality carry over into later relases of WAB?
Thanks!
43 Comments
AlixVezina
You are now be able to edit attributes in the table in the new Map Viewer, and in the Table widget in ArcGIS Experience Builder .
CesarAvila
Hi @AlixVezina
Is it me or the "Table widget' on the ArcGIS Experience Builder is not showing?
According to this blog, it's supposed to be on the "Basic" Widgets. https://enterprise.arcgis.com/en/experience-builder/latest/configure-widgets/widgets-overview.htm
AlixVezina
@CesarAvila The Table widget and some capabilities may not be available in earlier versions of Portal. I believe the Table widget will only be in Experience Builder for portal editions 10.9 and later.
If you are using an earlier version of Portal you may also use the latest edition of Experience Builder developer edition to get this widget.
