WAB : Widget Print : add PrintPlus features
1448
02-20-2019 05:01 AM
Status: Open
MagalyClément-Zaber
Hi!
Widget PrintPlus is awsome but have some bugs :
- The red rectangle is sometimes frozen, or disappear
- the scale is weird but not always...
After CTRL+F5, this troubles disappear...
But users are not satisfied...
What is interested is :
- To selected template to use,
- The preview of print area,
- The out Wkid,
- The scales to print
- The possibility to print attributes of the selected entity (not in default PrintPlus but simply added form "comment" and bloc "comment" in MXD template and a line in code : form.comment = this.map.infoWindow._contentPane.innerText)
thx
1 Comment
by Anonymous User
Magaly CLEMENT I agree. I would almost propose Esri implement Larry's UI.  Most important, it shows a graphical bounding box on the map for the area it will print. Users often request exactly that. Also, it shows a little slider with units like 1"=100 ft. It has standard scales engineers are used to. As others have indicated, most users do not delve in to the Advanced button. I was using PrintPlus but running into issues with new WAB builds.  Kory Kramer‌ any thought if the WAB Engineering may add Larry's PrintPlus UI/UX to the Print?
WAB Print Widget Configuration Suggestions
Have the default print service return layout map element dimensions
