My team is working in a project where web application have been configured using ArcGIS Portal's built in Web AppBuilder template of Foldable theme. In one of the business scenario we have to keep Time slider widget running and opened on the screen when other widget opened same time. This facility of opening multiple widgets is available in Dart and Launchpad theme but not in other themes. Can anyone please suggest any solution or take this an idea to implement so that multiple widgets along with Time slider can be opened simultaneously in Foldable theme as well.
Try adding it to the widget bar at the bottom of the widget customization window instead of the "Set the widgets controller" section. See image below
