Multi-Layer Field Attributes Filter Widget
852
07-22-2021 05:45 AM
Status: Open
AbdAhmad
There is two web layers , both of them has common attribute , one of the layers are contained within the other , the Idea is to enhance the existing default filter widget or create new widget to support the case when ever select a unique value from Layer A , only correspondent values appears on the list configured for web layer B. Something similar to the ArcGIS Dashboard  filter action that can be set between various layers . This helps when its required to eliminate list contents between 2 different layers that has common attributes . Example , Layer A : Blocks Boundary - contains Block Name , Block Code
Layer B: Subblock Boundaries - Contains Block Code , SubblockName , SubblockCode.
The workflow is to configure the filter widget to ask for values from layer A and once the user select any value  what will appear on the list configured for the Layer B is only the values that matches the selection from Layer A
Thanks
