Improvement to the select widget > color inside the polygon.
1599
07-22-2025 01:48 AM
Status: Closed
Labels (2)
AdélaïdeSautreuil
Hello,
I would like to see an improvement to the "selected" widget in terms of the appearance of the results on the map. Currently, when polygon objects are selected, only the outline is visible. Is it possible to have a color inside the polygon in addition to the outline? Because, for example, when many parcels are selected, there is a lack of visibility.
Thank you.
1 Comment
AlixVezina
Status changed to: Closed
@AdélaïdeSautreuil , thank you for posting your idea!
The team is no longer making enhancements to Web AppBuilder at this time and we recommend using Experience Builder moving forward to build your web apps.
In Experience Builder, you can customize the selection highlight color for selected polygon features from the Map widget settings.
