Complete groupfilter URL parameter syntax options
1826
09-29-2021 06:16 AM
Status: Open
HélèneTouyéras
The steps described in the ESRI online documentation to obtain a web app that has a URL with parameters used by the groupfilter widget. and it works! 🙂
The steps described in the ESRI online documentation allow to obtain a web app that has a URL with parameters used by the groupfilter widget.
Unfortunatetly, these parameters are restricted to selecting one or several discrete values (ref. ESRI Community Web AppBuilder question here)
Other common filter operators, although available in the widget, cannot be used via URL parameters:
  • filter on numeric values: greater than, lower than, greater than or equals , lower than or equals ;
  • filter on dates: date before... ; date after ....
  • filter on string parts: contains, starts with, ends with
  • exclusion filter: not equals to
Could these filter operators be added to the URL parameters? If so, could the documentation be completed with syntax examples?
Many thanks!
With kind regards,
Hélène.
2 Comments
AlixVezina
Thank you for posting this idea. We have taken note of your request and will let you know if this is planned in a future update of Web AppBuilder.
Please note that the current development efforts are mainly focused on Experience Builder, and this idea would also be valid for the Experience Builder Filter widget.
@Jianxia @TonghuiMing
HélèneTouyéras
Sounds fair! Thanks for your quick reply, @AlixVezina !
