Attribute Table Widget Dropdown List Filter
2229
03-24-2017 07:33 AM
Status: Open
AmyKlug
In Web AppBuilder, it would be WONDERFUL AND AMAZING if you could add dropdown filters with checkboxes for each field in the attribute table widget (like they have in Excel) so you can choose only the values from each field you want to view and have them show up on the map as well. Also an easy "clear filter" option to go with it, select and deselect all, filter multiple fields at the same time and have it be able to read more than 1000 records even if the service is set up to only send 1000 records at a time. PLEASE!
Thank You!
1 Comment
AmyKlug
for example a filter for each field that can build on the last filter
