Add "Get Point From GPS" button to Edit widget toolbar
953
06-21-2016 01:22 PM
Status: Open
NathanShaub
Collector is sometimes limited if you want to create an app with a bit more functionality (e.g., add custom themes/widgets), but it DOES allow the user to collect features using the device location.  If you use the out-of-the-box Edit widget in Web App Builder, you can't currently collect points/vertices with the device location ... it's necessary to place the point on the screen using aerials and/or the My Location widget marker.  And hopefully your fingers are nimble enough to get the point right where you want it to be.  I would love to see a "Get Point From GPS" button on the toolbar of the out-of-the-box Edit widget.
