A widget that uses survey123 connect forms
1275
06-12-2018 06:42 PM
Status: Open
JulioGaspar1
Hello,
It would be interesting to create a widget that uses the forms generated by Survey123 connect. Survey123 forms are easy to create and meet general needs that are not yet implemented. Without a score that stays with a line of improvement continues because whenever Survey123 improves this widget will follow, instead of its "brother" - Smart Editor - that takes a lot to have the implements.
Thanks
2 Comments
ScottPrindle
Hello Julio Gaspar,
Thank you for submitting this idea! Could you expand on the need for the Survey123 form to be edited through Web AppBuilder? Can the web form for Survey123 be utilized, or does this workflow require Web AppBuilder? How are you currently addressing this limitation in your workflows?
Scott
JulioGaspar1
Hi Scott,
The web form does not has the update capability as survey123 app - the inbox function.
The user experience is better with the widget too. With the web form, the user needs to open a new tab, load more things, and here in Brazil we don´t have in all locations a minimal required network.
Cheers,
Julio
