Silverlight, flex and .Net (viewers) don???t start,
2514
05-22-2013 01:11 PM
JamalNUMAN
Legendary Contributor
Silverlight, flex and .Net (viewers) don�??t start,
I have posted this issue multiple times but sounds not root answer for it.
It happens very often that when I start the Silverlight, flex and .Net then I got error message
http://p1/Builder/Default.aspx
http://P1/flexviewers
http://p1/ArcGIS/Manager
[ATTACH=CONFIG]24598[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
DerekLaw
Esri Esteemed Contributor
Hi Jamal,
Did the web applications work previously and have now stopped working? or
Are these brand new installations and they simply do not run?
Do you have the appropriate admin privileges on your computer when you installed the software?
Have you checked the status of your web server? (i.e., is IIS working properly?)
Hope this helps,
JamalNUMAN
Hi Jamal,
Hope this helps,
This is what surprises me the most: these applications are used to work properly + I do have full permissions + my web server is working fine
What might be the issue then?
Don�??t these applications work on the link bases? i.e, once we stick the link on any browser then they should work. True?
Jamal Numan
DerekLaw
Hi Jamal,
Something in your OS/web server configuration(s) likely must have changed between the time the applications were working and now not working. I haven't heard of the ArcGIS Viewers for Flex and Silverlight all of a sudden stop working for no apparent reason.
Please contact Esri Technical Support - they are best equipped to help you troubleshoot and diagnose the problem.
Good luck,
JamalNUMAN
Hi Jamal,
Good luck,
Many thanks Derek.
Best
Jamal
Jamal Numan
