Silverlight 3.1 builder/apps fails to start,
4027
05-26-2013 08:39 AM
JamalNUMAN
Legendary Contributor
This is one of the most frustrating problems in viewers.
I was able to build 3 web applications. The next day I couldn�??t
[ATTACH=CONFIG]24685[/ATTACH]
�?� Launch the Silverlight web application
[ATTACH=CONFIG]24686[/ATTACH], [ATTACH=CONFIG]24687[/ATTACH]
�?� To launch the already built applications
[ATTACH=CONFIG]24688[/ATTACH], [ATTACH=CONFIG]24689[/ATTACH]
What might be the issue here?
Is the �??ArcGIS Viewer for Silverlight 3.1�?� fragile?
Thank you
Best
Jamal
Jamal Numan
DerekLaw
Esri Esteemed Contributor
Hi Jamal,
I suspect something in your OS/web server configuration(s) likely must have changed between the time the applications were working and now not working. I haven't heard of the ArcGIS Viewer for Silverlight all of a sudden stop working for no apparent reason.
Please contact Esri Technical Support - they are best equipped to help you troubleshoot and diagnose the problem.
Good luck,
by Anonymous User
Not applicable
Original User: [email protected]
Hi Jamal,
Good luck,
Many thanks
Best
Jamal
