Select and assign graphics ......
3897
5
11-05-2013 08:49 AM
YurongTan
I have a query that returns a list of records that are related to various States (polygons) and I want to link those records to the individual States.  I am having problems to extract the individual States from the State boundary GraphicsLayer. here a set of the codes:
private Graphic getStateBoundaryGraphic(string ST)
    GraphicsLayer usaGraphics = MyMap.Layers["StatesUSA"] as GraphicsLayer;
    Graphic state = new Graphic();
    foreach (Graphic g in usaGraphics)
        if (g.Attributes["STATE"] == ST) state = g;
    return state;
[ERROR MESSAGE:]  "foreach (Graphic g in usaGraphics)" Object reference is not set which is null which is NOT true.
What am I missing?  Thanks
YurongTan
Thanks for all who responded.
The key is that (1) the Shape column must be included (or existing) in the Map Service Layer and (2) the query's parameter xxx.ReturnedGeometry must be set to true.  Then you can do whatever you want to do (clone, capture attributes, geometry, etc.) with the returned graphic.  Cheers
PietaSwanepoel2
Is MyMap.Layers["StatesUSA"] a graphics layer
Is STATE an attribute in MyMap.Layers["StatesUSA"]?
Is g.Attributes["STATE"] as string? Try g.Attribute["STATE"].ToString()
Did you define the variable "state" as Graphic?
YurongTan
XAML file: <esri:ArcGISDynamicMapServiceLayer ID="StatesUSA" Opacity="0.8" Visible="True"
                        Url="http://oigcodevgis:6080/ArcGIS/rest/services/StateBoundary/MapServer" />
Attributes:
OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
SFIP ( type: esriFieldTypeString , alias: SFIP , length: 4 )
SNAME ( type: esriFieldTypeString , alias: SNAME , length: 24 )
ST ( type: esriFieldTypeString , alias: ST , length: 4 )
GlobalID ( type: esriFieldTypeGlobalID , alias: GlobalID , length: 38 )
Shape ( type: esriFieldTypeGeometry , alias: Shape )
Shape.STArea() ( type: esriFieldTypeDouble , alias: Shape.STArea() )
Shape.STLength() ( type: esriFieldTypeDouble , alias: Shape.STLength() )
C# file:
myPolyGraphics = MyMap.Layers["StatesUSA"] as GraphicsLayer;
It says myPolyGraphics is NOT defined or nonreferenced.  Any clue?  Thanks
brettangel
Have you tried referencing it using the GraphicsLayer.ID or GraphicsLayer.GetValue(MapApplication.LayerNameProperty, "MyGraphicsLayer") might work.
KarenEllett
It looks like the issue is that STATE is not actually an attribute in your feature class.  Should you be referencing SNAME instead?
YurongTan
