Scale reference on layer
2366
04-11-2012 05:43 AM
DavidJosepha
Hi there,
I've a SVL application which contains 1 layer.
This layer in my mxd has a scale to be turned on at 10000.
But when I add this layer to my SVL application it's show the data on any level which is not what I want. I want it to turn on at 10000.
I've looked in the configuration of the layer in SVL but didn't found nothing.
Is there a way I can accomplish this.
Thank you,
David
BrianLeroux
I have a map service with multiple layers with each have different scales to turn on and off. They work fine in my Silverlight Viewer apps. Do the scales work when previewing th Java from the rest endpoint? One thing I noticed with SL Viewer is that when you make changes to a service, sometimes I have to re-add the service to the map if it is a pre-existing map. Clearing the REST Cache has also helped when republishing changes to a service. Hope that helps..
