Problem upgrading from 3.2 to 3.3 and problem for installing 3.3 from new
4516
02-23-2015 09:59 AM
Hector_Manuel_MartÃ_Â_nez_Luz
Upgrade from 3.2 to 3.3 did not work, when trying to run an empty project the viewer can not load, the problem seems to be in the tools.xml this because if I comment the configuration part of the tool it loads. I think it could be related to the use of the 3.2 template project, do not know really. Debug does not even reach the load configuration code of the tool.
I remove everything and install only 3.3 version of api, viewer, extensibility, but know i can not found template projects. Something similar happens to me when i install 3.2 but at the moment i found that the template was in a wrong folder after installation, know (in 3.3) I can not find anywhere the template.
Help please, i do not have too much time to solve this.
Regards,
Manuel
