Full Extent behavior ( globe icon)
3204
01-31-2012 01:23 AM
DavideLimosani
Hi all,
when I click on the full extent button the extent dispalyed is taken from the service of the current basemap. Is there a way to show the initial extent instead?
thank you in advance
Davide
DavidJosepha
Hi Davide,
Have you managed to control your full extent. I'm having the same problem.
Regards,
David
KarenEllett
There's a custom add-in available at http://www.arcgis.com/home/item.html?id=a98029bff6684cf49b2b42c58699c491 that I think does what you're looking for.  Upload it as an add-in, and then when you add it to your application you can configure it so that the 'full extent' is whatever extent you want it to be.
Hope that helps!
