Editable layers
1610
01-20-2012 11:35 AM
ChadHinckley1
In ArcGIS Viewer for Silverlight, I brought in a web map from arcgis online.  When I add the editor tool, I was expecting to be able to edit the layers that came with the web map.  Is this a possiblity or not.
IdahoHunter
DerekLaw
Esri Esteemed Contributor
Hi there,
Yes, the workflow you describe should work. Does your Web Map contain an editable feature service?
Editing features
Hope this helps,
ChadHinckley1
Hi Derek,
No, I used a compressed shapefile.  I could edit the features on ArcGIS online, so I figured I would be able to edit them in this application.
Chad
DerekLaw
Hi Chad,
To confirm, the ArcGIS Viewer for Silverlight supports web editing using feature services only. It does not enable editing of shapefiles.
Hope this helps,
