ArcGIS Viewer for Silverlight-Title on Tab?
3580
09-04-2014 01:49 PM
DougEwell
I'm using the ArcGIS Viewer for Silverlight. I copied one of my existing sites and then re-worked the layers, tools, etc to achieve what I need.  However, the tab label (in Firefox) still shows the title of the first site that was copied.  Where can I change this within the Silverlight Application Builder?
YueWu1
by Esri Regular Contributor
Technically, the default folder you need to check about Silverlight Application Builder is this path: "C:\inetpub\wwwroot\Apps\Your Application name\Config" and all layouts under "Layouts" folder
Here is a related documentation about creat a custom layout: ArcGIS Viewer for Silverlight Create a custom layout
Hope this helps!
DougEwell
Thanks for the reply.  In which file would I find the text to be edited? I did see the tab text in an 'Index' file and changed it there, but it didn't change on the tab itself after saving and exiting  the file.
